Originally Posted by redtegra21
The idle isn't very smooth. It almost sounds as if it is misfiring. I changed the spark plugs with Bosch Platinum Plus. The old ones didn't have a gas smell to them. Just black and smelled burned like they were old and been in there to long. Plus they were copper with the wrong heat range. So last person put the wrong ones in. After that, the idle was a little smoother, but still pretty rough to me. Any other sensors I should check out?? Like MAP or any other vacuum lines that are common leaks?
Good -- "sounds like it's misfiring" is consistent with the DTC 25 & 26. At least the right thing is being detected.
Sorry you bought Botch, but I guess any port in a storm. How's the plug wires look (like, maybe look under the hood after dark, while the car is running). If the last joker put in cheap-o plugs, he may've put crappy plug wires on there, too. I'd also pop off the distributor cap and take a look at the contacts inside the cap and on the rotor -- burned contacts can cause a pretty rough idle.
I wouldn't really expect that the emissions stuff could cause a rough enough idle to trigger a DTC 25 / 26. A problem with the injectors could possibly cause it, but that's such a pain to troubleshoot I'd make sure the ignition system isn't at fault first.
