gen 3 rough idle and acceleration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-21-2009, 12:51 AM   #1 (permalink)
sgtreis58
View sgtreis58's Photo Gallery
Hi all. I have a '92 3VZ-FE camry that has recently just started running rough, it sounds like a miss. I have replaced the plugs, distributor cap, rotor, and wires and I still have a rough engine. I have used fuel injector cleaner in the tank twice in the past four weeks. I bought the car in 2004 and have not replaced any parts or belts. Any ideas or thougts would be greatly appreciated.
Thank You.
sgtreis58 is offline   Reply With Quote
Old 05-21-2009, 01:01 AM   #2 (permalink)
View 500KCamry's Photo Gallery
Thank You.
How about getting a spray can of air intake cleaner. Does wonders for the I4 and the other V6.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 05-21-2009, 02:13 AM   #3 (permalink)
whip_cracker's Avatar
View whip_cracker's Photo Gallery
Running rough... meaning the car's making a rough noise? Does it actually move so to speak?
Does the idle drop suddenly? Could be a dirty IAC valve (easy to clean - sometimes needs replacing - trivial job really... even I can do it :P ) You'd also clean the butterfly clip too...
I'd be interested to see if it happened when in Neutral mate. There's a few things it could be, but need a tad more information champ.
whip_cracker is offline   Reply With Quote
Old 05-29-2009, 11:26 PM   #4 (permalink)
sgtreis58
Thanks for the reply's everyone. I replaced the remainder of the plug wires, the ones in the back that I could not see at night, and the car runs like new again. I routinely run Lucas Oil injector cleaner in the tank twice a month and clean the intake with spray once in a while. I put NGK platinums in and gapped them at .44. I got this info from AutoZone, just making sure it is correct.
Has anybody use the Seafoam in the intake before? Just wondering if it really works.
