Car shakes when I brake? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-21-2009, 08:03 PM   #1 (permalink)
View SmartedPanda's Photo Gallery
When I'm going above 50MPH, and touch the brakes, the whole car shakes, it just recently happened maybe a month ago, and I installed new set of brakes maybe 6-7 months ago if that helps.
I'm honestly scared to brake my car at times, it shakes my WHOLE freaking car man.
1992 Camry. 4dr Sedan. 3rd Gen.
2.2L 5S-FE I4, with ~167K Miles.
Trying to get my baby restored...
So Far: Dual XHD-6425
SmartedPanda is online now   Reply With Quote
Old 05-21-2009, 09:04 PM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Your rotors are warped. Go get new ones or have them resurfaced.
5 Lug Corolla WHAT?
Old 05-21-2009, 11:04 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Most likely warped rotor. (And you do periodically rotate and balance your tires?)
What brake pads did you use? Did you use a torque wrench on the lug nuts? Harbor Freight has 1/2"-drive 150 lb/ft for < $15. There should be one in every trunk as far as I'm concerned.
Old 05-22-2009, 03:30 PM   #4 (permalink)
View warlock's Photo Gallery
Like said above youe rotors are worped. Mostlikely cosed by over or uneven torq of the lugnuts. There is 2 ways to fix them. Have them reserfised or replace. Always torq your lugs to spec. I even redo mine at home after I go to the tire shop
94 Scepter 1MZ-FE
< TN Type [R]ice Club>RICERS UNITE!! Join Type R..latest faction of TN!!
.....http://www.toyotanation.com/forum/sh...d.php?t=105457
warlock is offline   Reply With Quote
Old 05-22-2009, 07:45 PM   #5 (permalink)
PortugalFocus's Avatar
Gameroom cash: $124395
View PortugalFocus's Photo Gallery
It's also possible one of the guide pins on the caliper is frozen or sticking. Try taking everything part and cleaning it then putting it all back together. If it's still there, then you most likely have warped rotors like everyone is saying.
PortugalFocus is offline   Reply With Quote
Old 05-22-2009, 09:33 PM   #6 (permalink)
Not real likely. Just for the fact the guide pins don't move that much. And when that dose happen the car dramaticly swerves to the side that is working right.
94 Scepter 1MZ-FE
Old 05-23-2009, 07:51 AM   #7 (permalink)
View flyeri's Photo Gallery
Not always. You probably have a warped rotor but if you are going to take it apart you might as well check for any other problems. I found a stuck guide pin and had no swerving. I also suggest a torque wrench for your lugs. Most shops now use a torque stick on their air guns which gets the torques much more even on the lug nuts. While this is not 100% it has helped cut back on warped rotors due to uneven torque.
flyeri is offline   Reply With Quote
Old 05-23-2009, 01:26 PM   #8 (permalink)
View nuron's Photo Gallery
Aren't torque wrenches sensitive to vibration? Even though the HF ones are cheap...
nuron is offline   Reply With Quote
Old 05-23-2009, 02:07 PM   #9 (permalink)
Yes thay are. Mainly the rod type and the electric ones. That's why I carry the twist type. Its spring loaded you just need to make sure you always back it all the way back when not in use
94 Scepter 1MZ-FE
Old 05-24-2009, 12:07 AM   #10 (permalink)
Thanks, I'll check my brake rotors. It's more of my steering wheel then my actual car.
Old 05-24-2009, 02:43 AM   #11 (permalink)
That is where you will feel it. Real drivers feel there car from the wheel and gas/brake pedle. Also from the shifter if you have a stick
94 Scepter 1MZ-FE
Old 06-25-2009, 10:36 PM   #12 (permalink)
Any way of knowing 100% it's warped?
I rotated my tires, and it feels much better but it still shudders.
Any aftermarket suggestions?
Any larger disk brakes?
Any way to know 100%?
Thank You.
Old 06-26-2009, 12:59 AM   #13 (permalink)
Turning a torque wrench needs to be a slow and smooth motion.
HF seems like the same ones sold in parts stores and Walmart at higher prices, but seems accurate compared against beam type.
I also have Danaher-made Craftsman and Kobalt (Lowe's). The Kobalts are better made, with metal lock rings. The Craftsmans, I heard, break the plastic lock rings all the time and the handles can turn loose from repeated use (lock nut came loose).
And guess which one has a lifetime (excluding calibration) warranty? HF!
Old 06-26-2009, 01:05 AM   #14 (permalink)
You're right you need to properly diagnose it before starting parts replacement.
You (or the mechanic) can use a dial caliper to check the rotors for runouts. If the dial move a good deal (forgot what the tolerance was), you have a warped rotor.
There are other things that can cause vibrations, but you usually have them even before you step on the brakes. (for example, alignment and wheel balance). Sure, like others said, caliper and anchor pin sticking may contribute as well.
Thank You.
Old 06-26-2009, 01:08 AM   #15 (permalink)
Ummm, not dial caliper. Dial indicator, mounted in a suitable magnetic or clamp holder. Like the following:
http://www.harborfreight.com/cpi/cta...Itemnumber=623
