how to adjust hand brake - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-21-2009, 11:46 PM   #1 (permalink)
View sc2dave's Photo Gallery
so how do i adjust it? 95 Camry. Also, what years are the same for the struts that'll fit? Thanks
sc2dave is offline   Reply With Quote
Old 05-22-2009, 04:50 AM   #2 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
General handbrake adjusting:
Handbrake off and take the rear wheels off ( i don't need to tell you you need the rear off the ground with the front wheels chocked). There should be a little hole in the hub and a small gear inside. You turn that down and it clicks. You can either:
> turn it until it grabs a fair bit and then spin it back the other way 8 notches. Will help if you get a scriber to lift the metal tab that goes over the gear and makes the 'click' sound, otherwise you might chew up the teeth on the gear with the screwdriver that's turning it
> let it grab a little(more than a slight grab) and then back it off 3 notches.
Once the pads are set properly you may need to adjust the cable. To do this, you need to remove the centre console. Then near the handbrake lever, you should see the cable and 2 nuts at the end of it. Undo the top one which is the locknut and adjust as necessary. Set it so the lever stops after 5 clicks.
Jimnist is offline   Reply With Quote
Old 05-22-2009, 08:16 AM   #3 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
IIRC, the emergency brake is self-adjusting -- just give it a few yanks. If it's really bad, then Jimnist gave the procedure...
Old 05-22-2009, 10:43 PM   #4 (permalink)
View 500KCamry's Photo Gallery
Did not know that - learn something every day - will give it a try.
A long. long, long, long time ago - I had a Ford - and was told the rear drum brakes coulds adjust by driving backwards and then braking hard. Don't know if this was true.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 05-23-2009, 02:50 AM   #5 (permalink)
Originally Posted by 500KCamry View Post
and was told the rear drum brakes could adjust by driving backwards and then braking hard. Don't know if this was true.
Yeah, i heard this too.I've tried it a few times on this car but nothing.
Old 05-23-2009, 02:50 AM   #6 (permalink)
what about for the struts?
Old 05-23-2009, 07:20 AM   #7 (permalink)
Gameroom cash: $105400
View dz63's Photo Gallery
sc2dave - I wrote a DIY procedure to replace the parking brake cables that includes instructions with photos on how to adjust the rear star wheels and remove the center console to get at the parking brake cable adjustment nut. Take a look, I think you will find the photos helpful.
DIY: GEN3 2.2L Parking Brake Cable Replacement Procedure
I can't help you with struts. Haven't done those yet.
2002 Camry 2.4L Auto - 70K miles
2008 Corolla 1.8L Auto - 48K miles
dz63 is offline   Reply With Quote
