97 V6 Valve ajustment- example pricing / diy difficulty - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2009, 02:12 PM   #1 (permalink)
'97 Camry V6 XLE
View thegmann's Photo Gallery
4th Generation 97 V6 Valve ajustment- example pricing / diy difficulty
My 97 Camry v6 xle is making a ticking click noise from under the valve cover. I figure its a valve that is out of adjustment. Apparently valve adjustments fall under routine maintenance ( every 60,000 miles) but I'm not sure if my car has ever had that done.
So I asked my local shop to take a look while they were replacing my spark plugs and valve cover gaskets recently and was told the adjustment would cost about 800 dollars. Unfortunately I don't have that much to spare.
So my question: Is that a decent price for that kind of work ( which it really doesn't to me after reading the steps in my service manual) and if not how hard is the job to do yourself?
Thanks for the help guys.
thegmann is offline   Reply With Quote
Old 05-22-2009, 02:40 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Since adjustments are all using shims, the process is quite tedious (and, of course, getting to the rear bank on a V6 is just freakin' enjoyable). It's not technically difficult, 'tho.
While the manual calls out valve adjustment every 60K miles, those valves hardly every go out of adjustment. Before you start twiddling things, I'd take a real close look under the valve cover for other possibilities.
Old 05-22-2009, 08:47 PM   #3 (permalink)
'97 Camry V6 XLE
What other things should I be looking for?
