Need a part number for this bracket - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2009, 11:48 PM   #1 (permalink)
Import Tuning
camry man68's Avatar
View camry man68's Photo Gallery
4th Generation Need a part number for this bracket
I have this bracket that I need to replace, I can't find a part number for it. "R 790D" is inscribed on the back of it, yet when I searched using that number nothing came up. So to give a little description, its the bracket that the rear sway bar bushing bracket attaches to. So pretty much this bracket is sandwiched between the rear sway bar bracket and a cross member that goes across the rear under body of the car. Here is a picture of the bracket:
If you are wondering why I am going through the trouble of replacing it, it is because when I was removing my sway bar I was unbolting a bolt from that bracket and the bolt was old and rusted so the head of the bolt broke completely off from the bolt itself which is stuck in the bracket pictured above. Yes, I could drill it out but it would be easier to just buy another bracket. So does anybody know the part number or know of a source where I could find the part number?
camry man68 is offline   Reply With Quote
Old 05-23-2009, 12:29 AM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
http://www.toyodiy.com/parts/p_U_199...PNKA_5102.html
BTW, I did the same thing on my car......
5 Lug Corolla WHAT?
Old 05-23-2009, 12:46 AM   #3 (permalink)
Import Tuning
Thanks
Old 05-23-2009, 12:50 AM   #4 (permalink)
View 500KCamry's Photo Gallery
Me too, broke the same bolt on both sides.
They drill out and tap nicely though. Think the cavity is the culprit - if it were sealed off with silicone it would keep the water and corrosion out, maybe the bolts would come out easier next time. There will be a next time as those rubber/silicone bushings wear fast if the roads are rough.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
