spark plugs and cables and cap. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-23-2009, 07:52 PM   #1 (permalink)
Momentum Car Crew Camry
View H.Rivera's Photo Gallery
ive searched and seen quite a few answers but nothing is consistent. so my question are.
What is a good spark plug and cable combination that promotes performance?
and
Does the cap really mater? Ive seen the clear ones but dont really see a difference.
H.Rivera is offline   Reply With Quote
Old 05-23-2009, 08:31 PM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
OEM plugs and wires. yoiur not goin to even gain 1hp with anything else unless your modded.
5 Lug Corolla WHAT?
Old 05-23-2009, 08:47 PM   #3 (permalink)
View SamKT's Photo Gallery
Newer Camrys are already running Iridiums. And I'm not sure if E3 is going to do that much more unless you add MSD ignition, but those parts are available primarily for Detroit hot rodders (I haven't search their catalogs).
http://www.e3sparkplugs.com/
http://www.msdignition.com/
SamKT is offline   Reply With Quote
Old 05-23-2009, 09:37 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
What kind of car? Depending on the year and engine, the car may not have a distributor.
Cars 92-01 had platinum plugs and some had dual ground dual platinum plugs because of the ignition system. Get the ones appropriate for your car because getting the wrong ones will reduce service life of the plugs by as much as half.
Iridium plugs won't do much that will be noticeable and may just be an unnecessary expense and can reduce service life if they don't have platinum on the ground electrode. But this will depend on the car you have.
2007 Camry 2.4L 5M
Old 05-23-2009, 11:48 PM   #5 (permalink)
roy7777's Avatar
View roy7777's Photo Gallery
My car is 96 camry v6.
Recently I use the NGK Power Cable & NGK Iridium spark plug.
Can't feel any different.
Just gain some psychological power.
roy7777 is offline   Reply With Quote
Old 05-24-2009, 07:44 AM   #6 (permalink)
so spark plugs and cables are pointless so what should be modded first.? so far everything is stock.
Old 05-24-2009, 07:45 PM   #7 (permalink)
View 500KCamry's Photo Gallery
I've seen a lot of discussion on air intake conversions - must be done for performance enhancement and seems like it would not hurt the pocket book too much.
Search the forums and the DIY threads to find out what you gain versus cost.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
