Same thing happened to me!!!!
OK...... the Stealership will charge about $75 for the whole piece. Get it if you can afford it! Its worth it!
If NOT...... do NOT replace bits and pieces of one line. REPLACE THE WHOLE LINE! I tried with one area.... then guess what?! Another leak on the same line later that day. I replaced THAT section.... then ANOTHER leak on the same line.
Replace the whole line!
BTW I didnt not have to drop the tank. It took 35 minuites to replace the thing. And you are going to get fluid all over Im guessing so prepare!
