Originally Posted by asian432003
No, I am not sure where that leaks from, I cleaned the hole yesterday when I fill some more fluid in.
It seem like no crack on the line but around the pump there is oil dripping.
Have you get any idea  How to identify and what to do
Thanks in advance!!!
This happened to my Gen 2 a few months ago. It was the high pressure hose. The pump looked soaked, so i thought it might've been the joint/connection at the pump, but fluid was leaking down the hose onto the pump.
Best way to test this is to turn the engine on (still parked), dry steer to full lock a few times. Turn engine off and look for leaks. If it dropped a fair amount of fluid, it's the high pressure hose (easy to identify when parking as well if you're still using it as a daily driver).
