I've got a 94 camry 4cyl auto with 230K miles. It's had a loping idle after the car is warmed up. Basically what happens is when you're stopped with the car in gear and your foot on the brake, the RPMs will start to fall and then will pop back up. The problem is intermittent and the loping is random but it's getting worse with the warmer weather. The car stalled when backing out of a parking spot a couple of days ago.
I've cleaned throttle body, IACV, new plugs, and have checked for vaccum leaks. When I ran a container of Chevron Techron through the gas, the problem went away. Unfortunately, it came back when I had to put a new tank of gas in. I've added another round of Techron and it's running fine right now. I suspect the problem will come back when this tank of gas is burned up. What does this indicate?
I don't really want to spend $9 a fillup for a container of Techron every time I buy gas.
Any comments/suggestions appreciated.
