Camry Xle V6 Brake Dilemma - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-27-2009, 03:11 AM   #1 (permalink)
TN User
View baber's Photo Gallery
4th Generation Camry Xle V6 Brake Dilemma
Hi Friends,
I have a 1998 Toyota Camry XLE V6. My brakes have worn out. Actually I'm planning to replace only the front brakes and rotors this time as I do not have enough money. I will replace the rear brakes rotors later on. Can I do that? Or doing that would put uncessary high pressure on the front brakes?
baber is offline   Reply With Quote
Old 05-27-2009, 06:30 AM   #2 (permalink)
View Axxis8203's Photo Gallery
replacing the fronts will be fine as they do most of the work anyway. as long as the rears aren't worn too much, you should be in good shape.
Wise Men STILL seek Him!
Axxis8203 is offline   Reply With Quote
Old 05-27-2009, 12:16 PM   #3 (permalink)
View 500KCamry's Photo Gallery
What he says.
I'f you're low on funds, you could also see if the old rotors can be turned and reused. If your old pads did not wear down to the backing plate, the rotors may even be reused without machining. Are both sides of the disc still smooth?
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
