96 Camry does not accelerate immediately when prompted, loss of power. HELP!
I have a 1996 Camry I4. It started off as a stalling problem, first when I went to pull in someones driveway and back out, the car stalled. The second time it stalled, I was going around a turn at 5-10 mph, foot off the gas.
Now the main problem is when I push the gas pedal, it wont accelerate to its maximum capability right away. And if I put the pedal to the metal, I hear one loud pop, sounding like a backfire. I tried changing the gas filter, but that didn't solve the problem. I used Seafoam in my gas tank to clean the fuel system, but that didn't help.
Once it gets past the initial hesitation, does she get up and go normally, or is accelleration pretty gutless all the way?
Is the check engine light on? If so, have you checked the code?
yes she gets up and goes normally after initial hesitation, just like a rocket! lol
and yes the check engine light is on. i brought it to Toyota and it had the code on paper saying the Shift Solenoid. This was before my current problem however. I was guessing the Shift Solenoid has something to do with my car having an abnormally long shift in 1st gear. I brought my car to my mechanic and he said I needed a new computer. Could these 2 problems be related?
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
Have you had a tuneup recently? Almost sounds like a coil going bad. Are you familiar with them?
choke the car lol. im assuming the neck is the tube where the TB connects to the air filter box. i know how to look at the air filter. can someone show me a few pictures of what the drivers side engine bay looks like, in detail so i can match everything up as best as possible?
and no im not familiar with a coil... im gonna look it up. thanks.
Sounds like she's running lean at low throttle. Since she goes OK at higher speeds, I don't think it's a fuel system issue or a problem with the MAP...my first suspect would be unmetered air getting in with the throttle plate closed.
Is the idle rough as a cob? What rpm does she idle at?
I'd inspect the vacuum hoses (diagram should be on the underside of the hood), and look for cracks, holes, or disconnected hoses.
Long shift? These Camrys have a big gap between 1st and 2nd. According to the specification sticky, 2nd gear is almost twice as long as first gear (1st=2.810, 2nd=1.549 for AT). Thus, a big drop in RPM should be expected during that first shift. I find it quite iratating, actually, in stop and go traffic.
by a long shift i mean the rpms skyrocket if you hold the gas down more than just a pinch, and the car jerks once it shifts into 1st. if you just barely push the gas pedal down, it wont jerk and it will shift without taking 3 or 4 seconds.
another thing that has me stumped is on the top of the transmission. right below the air filter and fuel filter, theres a plug that isn't connected to anything. it's got 2 green, 4" long wires which are connected to each other. i couldnt seem to find where it plugs into, if it even does because it's so short.
the idle when decelerating to 10mph or below can be very rough, but is intermittent and doesn't happen every time i slow down. and i believe she idles at normal rpms. where can i purchase replacement hoses? a couple are cracked at the ends, but still hold.
