Originally Posted by t3chnique
Anyone here removed their shift knob and replaced it with a aftermarket one that doesnt have a OD button?
is there any way to go without it or get around it?
any insight is appreciated.
I've had the shifter off once or twice. First, check the DIY section for the replacement WITH the OD button in the shifter. The only difference would be re-routing the wires from the original location of the OD button to somewhere else. I'd recommend putting it under the ECT button (gen3/3.5). It's only two wires for the OD button too, which is nice. Wires connected= OD OFF. Wires disconnected= OD ON. Technically, if you dont use OD, you could leave the wires disconnected and leave them alone.
