Originally Posted by MyFreeCamry
Ok so I have an opportunity to get a 1995 Coupe 5sfe/auto. Engine is blown in it. Plan is to trade my 1992 4dr for the coupe. I will be pulling my engine/trans out and putting it into the coupe. Now, mine is OBD1, the coupe is OBD2. Can I get by with just swapping engine/trans/engine harness or will I need to do a little bit more? Somebody let me know, I plan on making the deal tomorrow. Or if I can get $750 cash, the coupe is mine outright with clean title!!!!
Help me get a coupe. Thanks
Just put a 93 into a 95.
Differences were exhaust manifold and transaxle.
The 95 exhaust manifold has two 02 sensors, the 92 one.
On the 93 transaxle the starter connections are different, the multi-pin connector by the shift selector is narrower, and there is on extra connector on the rear of the transaxle.
You can make you 92 I4 work in the 95 coupe if you marry the 95 transaxle to your 92 I4 and put the 95 exhaust manifold on your 92 I4. Then there are no changes to the 95 coupe wiring harness.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
