Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2009, 12:24 PM   #1 (permalink)
View ddunn's Photo Gallery
Help
I have a 1997 camry. I replaced solenoid #2 as this was the problem per code PO755. The car will still not kick into reverse gear, can anybody give me any info on this
ddunn is offline   Reply With Quote
Old 06-01-2009, 01:43 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Which engine -- 4-banger or 6-banger (bit of a difference on the trannys)?
Old 06-01-2009, 01:46 PM   #3 (permalink)
Help
4 banger
Old 06-01-2009, 02:13 PM   #4 (permalink)
hill8570's Avatar
While you still had the tranny open, did you confirm the solenoid was operating (apply battery voltage to the solenoid & watch it actuate)?
Did reverse ever work on this tranny?
Are you still getting the P0775 after clearing the code and running a couple of trips (start, drive, shutoff engine, repeat)?
Do 1,2,3 and O/D work OK at the moment?
Old 06-01-2009, 02:40 PM   #5 (permalink)
Help
Yes reverse did work. 1,2,3, and o/d work fine now that replaced solenoid #2. My check engine light came on today. I'm going to see what the code is today.
Old 06-01-2009, 03:36 PM   #6 (permalink)
hill8570's Avatar
So, when did reverse stop working? Was it working up until you opend the tranny to replace S2?
Old 06-01-2009, 03:40 PM   #7 (permalink)
Help
No it was working fine and then my check engine light went on and the code said malfunction S2. Replaced S2 and still don't have reverse but 3 came back
