Diff Axle seal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2009, 04:22 PM   #1 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
3rd Generation Diff Axle seal
Hi, I noticed that the seal on my 95 5S-FE auto for my driver's side half shaft is leaking at the diff and I intend to replace it this weekend. My main question is will I be able to just pop out the old seal after removing the axle, or will I actually need a special tool?
Also, the Haynes manual says to use a large socket to press in the new seal. Does anyone know what size socket may be required?
I already have all of the other tools required to remove the axle (I HATE that part), and drain and fill the diff.
Will I need to buy anything besides the following?
seal
ATF (1.7q required)
I just want to make sure I have everything I need before I start, thanks.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 06-01-2009, 06:11 PM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Your best bet is to drill a hole in the seal with a small drill bit. Then, screw in a small sheet metal screw and pull the seal with a cats paw or claw hammer. If you have some PVC pipe laying around, try and match up the new seal diameter to it. You could go to Home Depot and match up a short piece of PVC to the new seal if you don't have any.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 06-01-2009, 06:33 PM   #3 (permalink)
View 500KCamry's Photo Gallery
seal
ATF (1.7q required)
Check to make sure you can loosen the differential fill plug before you pop the seal and remove the axle. It's a tough one sometimes.
The seal should pry out easy.
You should also get a new cotter pin for the axle nut keeper.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 06-01-2009, 06:47 PM   #4 (permalink)
'95 Camry 5S-FE
I'll check the diff fill plug, but I'm 99% sure I can get it seeing as how I have done a few diff fluid changes on her with no problems. Thanks for reminding me about the cotter pin, and I'll check out pvc pipes. I really don't want to drill the seal because I don't want any debris in the diff.
