Just to add. Take a good look at your large rubber intake pipe that goes from your air filter box to the throttle body. I have seen these split on several camrys. This usually triggers a "System to lean"code but just to be sure. Also, get your ECT checked. If your ECT resistance is too high at normal operating temperature, the ECU will put in more fuel than necessary.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door.  New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
