is all 1992-1996 camry trans same? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2009, 02:48 PM   #1 (permalink)
View JDM_KING's Photo Gallery
quick question, is all 1992-1996 camry trans the same? auto trans, 4cyl, LE.
JDM_KING is offline   Reply With Quote
Old 06-02-2009, 04:24 PM   #2 (permalink)
Do not buy from
View Zviator's Photo Gallery
there are 3 different engine model for this generation:
4cyls - 5sfe - from 92-96
6cyls - 3vz - from 92-93
6cyls - 1mz- from 94-96
Thus the auto trans wont be the same ...
Zviator is offline   Reply With Quote
Old 06-02-2009, 05:56 PM   #3 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Since he has the I4, it should all be the same...so he can get one from any 92-96, and more into the Gen4 also, if Im not mistaken.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 06-02-2009, 07:46 PM   #4 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
I thought that the 1mz was 95-96 and the 3vz was 92-94.
'07 Honda Ruckus Big Bore
Old 06-02-2009, 10:05 PM   #5 (permalink)
_
Gameroom cash: $221635
View uuuuu's Photo Gallery
For completeness, what about manual trans?
uuuuu is offline   Reply With Quote
Old 06-02-2009, 11:06 PM   #6 (permalink)
View 500KCamry's Photo Gallery
The automatic I4 has two transmission types, the only difference being external wiring.
The mounting mechanicals, axle locations, etc. are the same.
The 92 and 93 (maybe some of 94's) have an connector on the rear (firewall side by the fender and a narrower connector on the front side by the shifter cable.
My guess for the 95 and 96 (maybe some 94's) is that they re-routed wiring internally to get rid of the rear external electrical connection and place it on a wider connector by the shifter.
Also the elctrical connectors for the starter are different.
The short answer is that the trannys fit, but the wiring harnesses are different.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 06-03-2009, 01:04 AM   #7 (permalink)
Do not buy from
bigbird coupe is a 94 (first year ever with a coupe) with 1mz TRD supercharged
Old 06-03-2009, 11:50 AM   #8 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
E153 for the Manual V6 and IIRC S54 for the Manual I4.
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
Old 06-03-2009, 12:33 PM   #9 (permalink)
Proud Toyota Owner
CamryWilly's Avatar
View CamryWilly's Photo Gallery
3rd Generation
I'll set the record strait, for the I4 the manual trans was the S51 (S54 has it's shifting levers relocated for the MR2)
For the couple of rare V6 with the 5 speed, they came with the E53 and some REALLY rare ones (SE's, Lexus) they have the E153(that's the one you can get an LSD).
Hope this clears up things a bit...
CamryWilly is offline   Reply With Quote
Old 06-03-2009, 03:13 PM   #10 (permalink)
so, i need a 92-93 trans then? mine wont move in drive or any other gears but reverse.
Old 06-03-2009, 03:23 PM   #11 (permalink)
Bdub215's Avatar
Gameroom cash: $315565
View Bdub215's Photo Gallery
the lexus es300 has the E53 as does the SE. should put that in a sticky by itself
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 06-03-2009, 06:14 PM   #12 (permalink)
I4 - Auto - yes. You can check the 94 by eyeball, if it has the extra connector on the rear of the transaxle by firewall and close to the fender, then it will be the same as the 92/93.
Not sure where the 94 transaxles fit, whether they made internal wiring changes to the transaxle before 94, during 94 or after 94. You can tell by the extra connector at the rear and the width of the wide connector by the shifter (front of transaxle). If the 94 front connector is the same width as yours then it will fit the 92/93, if wider then it fits a 95/96.
Somewhere - I don't know where - there must be a list of Jap and NA VIN numbers that shows the transmission differences.
Good luck.
01 XLE V6 310K km
