Sunroof wiring question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2009, 04:53 PM   #1 (permalink)
View davetonih's Photo Gallery
4th Generation Sunroof wiring question
Have a 2001 Camry LE Gallery Edition. Sunroof was working until I had an electronic starter installed in January. I have two red wires in the interior fuse box behind my "coin " drawer on left side of steering wheel. One red wire is connected to FOG and the other is not connected to anything. I know it was connected before but I can't remember where. Anyone have an idea? I'm pretty sure these red wires are for the sunroof. It's getting warm out and I want to use it again. Thanks!
davetonih is offline   Reply With Quote
Old 06-03-2009, 01:39 PM   #2 (permalink)
Proud Toyota Owner
CamryWilly's Avatar
View CamryWilly's Photo Gallery
Just a friendly reminder, cause i also forget lol,
Did you check the fuses?
CamryWilly is offline   Reply With Quote
Old 06-03-2009, 01:42 PM   #3 (permalink)
Gameroom cash: $275055
You can download a generation 4 Toyota factory service manual over at the top of the Camry forum at AutomotiveForums.com. I suggest you go there and download it and then check the wiring section. It should give you the information you need.
Mike
Old 06-03-2009, 03:09 PM   #4 (permalink)
I will check the manual. Don't have a fuse labeled sunroof that I can find. If anyone knows where it is located, let me know.
I'll post it if I find it.
Old 06-03-2009, 09:57 PM   #5 (permalink)
View 500KCamry's Photo Gallery
The fuse is on the cuircuit board under the dash by the steering column, part the same circuit board is exposed when you remove the coin box.
The fuse is one of those pink square bodied 30A type that are fairly long and have a clear square plastic lid where you can see if the link is blown.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
