Replacing the valve cover - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2009, 07:18 PM   #1 (permalink)
93 Camry LE V6
Barcs's Avatar
View Barcs's Photo Gallery
Well, unfortunately my valve cover has a crack in it and needs to be replaced, since oil's starting to seap through. It seems like a very hard part to find without going to the dealership. The dealership wants something like $300 for one (which is absurd considering I can buy the whole engine used for $650), and most junkyards won't take them off. It's like I'm in a lose lose situation. Does anybody happen to know where I can get one of these used or cheap aftermarket?
It's for a 93 Camry LE V6 3.0L. Thanks.
Barcs
Barcs is offline   Reply With Quote
Old 06-03-2009, 07:37 PM   #2 (permalink)
93 Camry LE V6
Barcs's Avatar
I found one on ebay, and it says it should fit, but it looks different. The oil cap is in a different place although the shape looks similar.
http://cgi.ebay.com/ebaymotors/92-93...ayphotohosting
Hmmm. This is the engine I have and the valve cover looks a lot different.
Barcs
Old 06-03-2009, 07:39 PM   #3 (permalink)
View 500KCamry's Photo Gallery
Originally Posted by Barcs View Post
Well, unfortunately my valve cover has a crack in it and needs to be replaced, since oils starting to seap through. It seems like a very hard part to find without going to the dealership. The dealership wants something like $300 for one (which is absurd), and most junkyards won't take them off. It's like I'm in a lose lose situation. Does anybody happen to know where I can get one of these used or cheap aftermarket?
It's for a 93 Camry LE V6. Thanks.
That vintage of Camry should be in pick your part places, where they let you in to take what you want. Maybe you're choosing the wrong wrecker to go to.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 06-03-2009, 08:01 PM   #4 (permalink)
View Axxis8203's Photo Gallery
depending on where the crack is... why don't you take it to a local machine shop and see if they can't weld it for you.
Wise Men STILL seek Him!
Axxis8203 is offline   Reply With Quote
Old 06-03-2009, 08:40 PM   #5 (permalink)
93 Camry LE V6
Barcs's Avatar
I would, but the crack is right on the edge near one of the bolts.
That's a good idea. It's hard to find those kind of wreckers these days it seems. I will keep looking. Thanks!
Barcs
Old 06-04-2009, 08:59 AM   #6 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
I have a hairline crack on my valve cover, not near any bolting holes (5S FE) and am planning on brazing it together in a few weeks. I am involved with a deck project and my garage is full of wood and tools at the moment.
You should try the welding / brazing option at a local machine shop. Even if entire piece of metal to falls off (separates) the machine shop would weld and regrind that area to match.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 06-04-2009, 09:49 AM   #7 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
http://cgi.ebay.com/ebaymotors/92-93-94-95-TOYOTA-CAMRY-VALVE-COVER_W0QQitemZ180279872568QQcmdZViewItemQQptZMoto rs_Car_Truck_Parts_Accessories?hash=item29f9848c38 &_trksid=p4506.m20.l1116#ebayphotohosting
That is the 3VZ-FE (says on the timing cover). I guess you have a 1MZ-FE? Try other wreckers. With the self serve, they usually have cars out for you to pick at (inc engine bits) and keep the good engines (complete) in a room.
Jimnist is offline   Reply With Quote
Old 06-04-2009, 01:47 PM   #8 (permalink)
93 Camry LE V6
Barcs's Avatar
My engine is the 3VZ-FE in the picture. I'm guessing that other valve cover is from a 1MZ-FE. Don't Lexus ES300s also have a 3VZ-FE?
Barcs
Old 06-05-2009, 06:08 AM   #9 (permalink)
セクシーの定義
Possibly, i know for sure they had the 2VZ's(2.5L v6). If they did, it'll be a on the '2nd generation' ES300's.
Old 06-05-2009, 12:08 PM   #10 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
The '92 and '93 camry and ES300's used the 3VZ engine. The engine pictured is the 3VZ and the valve cover looks right. Maybe post up a pic of your engine? I've neer seen the 3VZ with the oil cap any other place than it shows in the picture.
cykaaro is offline   Reply With Quote
Old 06-05-2009, 12:51 PM   #11 (permalink)
Don't get mad. Get even.
El Tano's Avatar
View El Tano's Photo Gallery
Ask trd4life, he is a member here and he is parting out several V6's, maybe he can help you...
Here it's the link of what he is selling:
Huge TRD4life Partout! Gen 3 and 4 Camry, Gen 1 Solara Come check it out..
Good luck
El Tano is offline   Reply With Quote
Old 06-05-2009, 12:52 PM   #12 (permalink)
93 Camry LE V6
Barcs's Avatar
Ok, I ended up getting one from a junkyard that the guy guaranteed would fit. It looks like the one on ebay with the oil cap on the right hand side, although it's different from the one on my engine. I checked it with my gasket and it's a perfect fit. Strange that they have 2 different versions of the valve cover for the same engine. I'll post a picture when I replace it. My engine looks exactly like the one in the picture above.
Barcs
