92 camry tranny question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2009, 11:08 PM   #1 (permalink)
View camrygoonv's Photo Gallery
Hey TN, I just purchased a 92 camry I4 automatic. The car had a bad tranny, will only go front in every gear. No reverse. I brought a tranny from a junk yard and installed it. The car ran perfect for about a few hours. All of a sudden the tranny began to slip and hesitate at take off from dead stop. Then it was slipping completely. The car felt like it was in neutral in every gear. I'm not sure how may qts of oil I was supposed to put in a dry tranny. I only put 4 qts. Is this amount of oil good? Someone told me I was suppose to put 8 qts. Is this true?
camrygoonv is offline   Reply With Quote
Old 06-04-2009, 09:37 AM   #2 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
the manual said transaxle need total 5.9 qt
drain refill 1.7 qt
i am not sure if differential need 1.7 qt separately
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
