Gen 3 Specific Quesition - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2009, 12:55 PM   #1 (permalink)
View festaman's Photo Gallery
3rd Generation Gen 3 Specific Quesition
Well it looks liek alot of the pictures posted on shutter fly are now gone. I was wondering where you guys ran the power wire for amps through the fire wall. Also has anyone seen a 4 chan amp mounted on the underside of the rear deck? And lastly where did you run the rca's i was going to pull the seats out and just run them under the floor carpet.
Thanks for the help.
Brian - First time Poster
festaman is offline   Reply With Quote
Old 06-05-2009, 01:52 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
best way that exists is running it through the wheel well to the firewall. you have to remove the drivers wheel and splash guard to get to it. other then that jsut drill yourself a new hole.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 06-05-2009, 01:52 PM   #3 (permalink)
View KevinACrider's Photo Gallery
For the power wire you can run it through the firewall above the and/or beside the steering wheel. From there just pull of your door trim and run it under the carpet down the drivers side. Also run your remote wire down that side. Run your RCA cables the same way but on the passenger side. If you remove the bottom of the back seat it will be a lot easier to feed them into the trunk area.
As for the amp, you can mount it wherever you want. I probably wouldn't suggest the underside of the rear deck but with some wood screws you can attach it the back of backseats. I'm assuming you know how to do the ground wire correctly and securely but if not, just come back and I'll explain that for you too.
Good luck!
KevinACrider is offline   Reply With Quote
Old 06-05-2009, 03:18 PM   #4 (permalink)
Do not buy from
View Zviator's Photo Gallery
I'll do a write up on amp - subs wiring later on ...
Zviator is offline   Reply With Quote
Old 06-05-2009, 03:25 PM   #5 (permalink)
Ricer if you want any specific pictures I can take them tonight. My head unit just got here from UPS and I'll be installing it shortly.
Old 06-06-2009, 05:59 PM   #6 (permalink)
whip_cracker's Avatar
View whip_cracker's Photo Gallery
I ended up putting my 4 gauge power cable through the same wiring harness that all the other wires go through...there's two bolts that hold it onto the firewall, unscrew those, help feed it through... yeah, simple.
whip_cracker is offline   Reply With Quote
Old 06-06-2009, 06:08 PM   #7 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
That's the way I ended up running mine too, since there was already a wire that was done there for the remote/alarm system. Fairly easy to do and haven't had any issues at all in doing so.
cykaaro is offline   Reply With Quote
Old 06-08-2009, 12:07 PM   #8 (permalink)
All set
Thanks a lot for all the info. I went thought the grommet behind the splash guard.
Worked like a charm! Thanks
