extremely hard/stiff clutch pedal (camry gen3 1993) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2009, 01:09 PM   #1 (permalink)
View jaber's Photo Gallery
3rd Generation extremely hard/stiff clutch pedal (camry gen3 1993)
Hello all,
I bought my camry 5 years ago and since then the clutch is extremely stiff. i changed the clutch pressure plate twice and the whole clutch set thrice! and every time the stiffness declined only a little bit only to be stiff again in 3-5 months.
I've been googling about it for a long time as now the stiffness is at its highest ever (my leg joint hurts now!), but found nothing about it,
I did post about it before, but to no significant results as it was not a stock clutch, but now I have an original stock clutch.
Can anyone tell me what to do, the last clutch change was about 8 months ago?
jaber is offline   Reply With Quote
Old 06-06-2009, 01:51 PM   #2 (permalink)
no answer yet?
Old 06-06-2009, 01:57 PM   #3 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Clutch systems are pretty simple. If not the pressure plate, is your hydraulic clutch system working properly? Tried bleeding it?
If you have a cable clutch (which i doubt), is the cable binding?
Jimnist is offline   Reply With Quote
Old 06-06-2009, 09:00 PM   #4 (permalink)
Actually its a cable clutch system , can you explain the bleeding part and the hydraulic clutch system
Old 06-06-2009, 09:19 PM   #5 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
Adjust the master cylinder and try bleeding the clutch. That might do it
RichieRichJP is offline   Reply With Quote
Old 06-06-2009, 09:25 PM   #6 (permalink)
sorry I'm a complete noob at this! though I know how to bleed the system from youtube!
and yes its a hydraulic clutch system, sorry for the wrong info
Old 06-07-2009, 01:18 PM   #7 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
you bleed it at the slave cylinder- there is a nipple on it, and it is located on the front of the transmission.
then bleed it like you would a brake hydraulic system.
HaHa
Old 06-07-2009, 11:16 PM   #8 (permalink)
Thanks, really appreciate the help!!!
Old 08-06-2009, 02:16 PM   #9 (permalink)
Thanks guys!!!
I changed the master cylinder and clutch kit first
Now clutch is substantially soft!
Old 08-06-2009, 11:17 PM   #10 (permalink)
セクシーの定義
Yay!
I thought you said you replaced the entire hydraulic system thrice though(master cylinder + reservior, line and slave cylinder)? So you changed the master 4 times in total and only the 4th one was good? Talk about bad luck...
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Old 08-07-2009, 07:40 AM   #11 (permalink)
you betcha!
in this country, there is pretty much no one who can "perfectly" repair anything, let alone an old car!
