No power intermittently
Hi all,
I tried searching but didn't find anything quite like my problem. first my specs:
1992 camry LE 4cyl, USA. replaced alternator & battery 2.5 yrs ago. tested my battery today both disconnected (12.6v) and connected with car on (14.6v).
problem:
car turns on no problem when cold...if I need, for any reason to shut down the engine quickly, sometimes it will not run, after a couple (or sometimes as much as 15min) of minutes car will turn on and go on it's merry way with no problem. today it happened after i had been driving a good while and went to replace my car stereo. engine turned but did not turn on, after getting a boost car turned on fine...but like i said, battery/alt seem fine when I tested, also the batter/alt. light in the dash is not on, and last time i had alt trouble it did...i know it works...can it be the battery connectors? i made sure i tightened them really well after testing...let me know if you need more details for any type of Dx
Thanks,
All
