Originally Posted by Grimmjow
Never tried. But it will drive the car in reverse. So im assuming no crank
The same switch in the center console senses park and neutral the only two shifter settings where the engine starter will engage and crank. If the switch is faulty or a nut loose so that the shifter position is not being sensed properly, the engine could crank in other settings other than P and N.
Anyhow, I think you need to access the center console to check if its mechanical (nuts loose) or an electrical (the switch defective) problem.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
