How to diagnose oil leak in 97' 4 cyl - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2009, 12:47 PM   #1 (permalink)
View caveman017's Photo Gallery
Ive got a 1997 4 cyl with about 140k miles on it. The past few months or I so I have noticed some oil leaking onto my driveway. Looking underneath the car, I found a lot of oil on the bottom covering it. I noticed that right behind where you put the oil in at the top, I saw some oil as well. I'm thinking it may be the valve gasket, but I'm not sure.
Any way to diagnose this?
1997 Camry LE, i-4, auto, KYB GR-2 and mounts in the front
caveman017 is offline   Reply With Quote
Old 06-07-2009, 01:01 PM   #2 (permalink)
View 500KCamry's Photo Gallery
Try to retorque the four nuts that hold the cover down. Think they are 30 mm on the spark plug tubes.
With mine, I found a lot of oil on the rear of the block because of this type of leak.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 06-07-2009, 04:35 PM   #3 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
If your timing covers and acessory belts have oil on them, you may have leaky seals on the crank, cam or oil pump. You can buy a couple of cans of brake parts cleaner and spray down the oily area then drive the car and check where the leak is starting.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
