Pop off the cover to your relay/fuse box and check your fusible links. Check your battery terminals for corrosion and make sure there tight. Does the dome light come on when you open the door?
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
Clean and tighten the battery connections to begin with.
It's easy to connect booster cables and not get a good connection when you put them on battery post clamps. Also cables are prone to breaking.
In the forward fuse box in the engine compartment there's two fuse links closest to the left headlight, a 100A main and 60 or 80A (can't remember which) beside it. There are clear square lids on these, are they blown?
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
With no other symptoms before hand I'd have to agree with checking the terminals. I had issues with my positive cable doing this before I changed it out. Then go from there. Either way, it looks to be probably an electrical issue of some kind.
Can you check to see what the voltage is on the battery? Then rule that out or not.
I've had an issue where my terminal clamps weren't tight because they were both cracked on the bottom side, so you couldn't see it. But sure enough, it was enough to break the flow of power.
battery is in good condition, I know that for sure.
poped the fuse boxes, and there's no burnt out evidence.
dom light does not come on, nothing comes up.
i have remote started + entry, nothing responds.
I did have this check light telling me about an electrical problem for a while, the light comes up when a bulb is dead. I thought I got dead bulbs, but i replaced some and it didnt turn the warning light off.
battery was fine, fuse box was not. some loose connections in the fuse box due to the fact that the armor support for the box snapped and the box been dangling around.
big shout for crusin76 helping me for everything solving the prob for me
