Interesting. I may be wrong, but the ATF pump (sounds like it works as your gears engage) should have filled the converter for you. Sure, some like to prefill their converters like oil filters, but I don't think that's even necessary on the old Aisin A series transmission.
BTW, these are way better than the new U-series clunkers.
If you're sure all the areas on the converter shaft are correctly aligned, then give it some time to fill up in P/N w/ parking brake of course, making sure you have the correct level of ATF in the system.
A good way to tell is to insert a short segment of 3/8" clear vinyl tubing (using 2 barbed plastic connector like $1) in the cooler line. If there are no air bubbles you should be good.
Again, the main concern would be shaft alignment.
Originally Posted by tonyvlx
HELP. The trany is completely dead. It switches through the gears good, just no movement.any help would be appreciated. thanks
