Help Id Oil Leak! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-08-2009, 08:09 PM   #1 (permalink)
View haydeno's Photo Gallery
Help Id Oil Leak!
Hi, I seem to be leaking oil on the lower part of engine. Can you let me know what the leaking thing is. I have included pic of leak
haydeno is offline   Reply With Quote
Old 06-08-2009, 08:14 PM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
I'll take oil leaks for $500, Alex.
"This leaks as shown above."
What is the valve cover gasket?
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 06-08-2009, 08:16 PM   #3 (permalink)
Valve cover gasket not leaking at all and was changed about 20k ago. Its looks like ATF. It looks like the the sensor or what not is leaking??
Old 06-08-2009, 08:19 PM   #4 (permalink)
'95 Camry 5S-FE
In the picture, it looks like oil to me, but I could be wrong.
Also, oil leaks flow down, not up. So it can't be leaking from the sensor on top of the tranny.
Old 06-08-2009, 08:46 PM   #5 (permalink)
Gameroom cash: $197815
View Frodo65's Photo Gallery
It can if it's a pressure leak. Weeping gaskets or a cracked sensor body can weep enough oil to puddle. Clean area, maybe add dye to crankcase, and confirm source.
Frodo65 is offline   Reply With Quote
Old 06-09-2009, 12:33 AM   #6 (permalink)
v6camrydriver's Avatar
View v6camrydriver's Photo Gallery
I've also got a oil puddle in that spot and I've suspected it's coming from either the rear valve cover (it's a V6) or the distributor and dripping down. In this case it's more likely the valve cover as this engine dosen't appear to have a distributor.
If you look at the pics you can see what looks like oil residue on one of the pipes, though can't be sure from the picture.
v6camrydriver is offline   Reply With Quote
Old 06-09-2009, 07:20 AM   #7 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Did you use RTV on the corners of the cam journals when you replaced the vavle cover gasket? It does appear to be ATF but you need to get some on your finger or a rag and smell it to be sure. If it is indeed ATF, the part in your second pic appears to be the speedometer sensor. There is an o-ring on it that can go bad and looks to be the culprit here.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 07-29-2009, 12:59 AM   #8 (permalink)
View jgoh88's Photo Gallery
haydeno,
I have got the same problem with my 1998 camry too. Juz started 2 weeks ago. Let me know if you have found the solution.
Thanks in advance.
jgoh88 is offline   Reply With Quote
Old 07-29-2009, 03:08 AM   #9 (permalink)
asphalt victory's Avatar
View asphalt victory's Photo Gallery
heater hose leak? brake fluid?
MAY AN EMPTY PARTS BOX BE MY WINNING TROPHY
asphalt victory is offline   Reply With Quote
Old 07-29-2009, 03:27 AM   #10 (permalink)
It's black. Can it be brake fluid? My brake fluid reservoir is still normal.
Old 07-29-2009, 08:40 AM   #11 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
i have the same leak, and i thought it was my valve cover gasket too, and i redid VC gasket 2 time, still leak, turn out it was from the half moon and the "whole moon" where the distributor shaft goes in for gen 3. i know, the gen 4 is distributorless, but the hole is still there, cover with a round plastic.
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
Old 07-29-2009, 10:58 AM   #12 (permalink)
Great. I'll ask my mechanic to look there 1st. My appointment is this Saturday.
Thanks guys ... for all your input.
Old 07-29-2009, 11:04 AM   #13 (permalink)
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
i second this. simply replacing teh valve cover gasket without doing the half and whole moon plugs is like patching only one of the three holes in your leaky boat.
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
Old 07-31-2009, 08:13 PM   #14 (permalink)
View nevanerviss's Photo Gallery
I had that SAME leak; drove me crazy for a week, but it was, in fact, the distributor o-ring...
nevanerviss is offline   Reply With Quote
Old 08-02-2009, 02:41 AM   #15 (permalink)
Guys,
I've replaced the valve cover gasket, whole moon and half moon disc. The leak stopped. Thanks again for your input.
