Removal and installation of thermostat on a '94 Camry XLE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2009, 11:59 PM   #1 (permalink)
View BRomero's Photo Gallery
Hey guys, I need to change my thermostat cause apparently mine is stuck open. My question is, is it hard to change it on a '94 camry? Can I do it myself or should I take it to a shop? I already purchased it, I just need to install it.
BRomero is offline   Reply With Quote
Old 06-11-2009, 05:42 AM   #2 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $284080
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
pain in the ass to change, but not impossible, use the search function, if I am not mistaken it is on the lower radiator hose, the end by the block
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 06-11-2009, 08:54 AM   #3 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Gameroom cash: $191865
View RU2CHKN's Photo Gallery
I4 or V6?
RU2CHKN is offline   Reply With Quote
Old 06-11-2009, 09:10 AM   #4 (permalink)
View Camry LE 94's Photo Gallery
if you have the right tools, you can do anything
Camry LE 94 is offline   Reply With Quote
Old 06-11-2009, 09:06 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
I4 or V6? Both should be no problem if you're mechanically inclined. But may take a while on your first try because of clearance to some nuts/bolts. Refill with Toyota Red and distilled water. Good time to get a new radiator cap.
Disconnect the battery. Make sure no coolant gets into electrical parts. use tin foil to divert coolant if needed.
Old 06-11-2009, 10:51 PM   #6 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
The 4 banger is easier than the V6. Both are doable with a 3/8" or 1/4" socket set. Get a clean drain pan for the coolant and open the valve at the bottom of the radiator. Let all the coolant drain. Remove the bolts on the thermostat housing. Some more coolant will spill so have the drain pan positioned appropriately. Remove your old t-stat. Slip the new o-ring on the new t-stat. Seat the t-stat in the housing and put the bolts back on. Re-fill with 50/50 mix Toyota Red. Run car up to normal operating temperature and check for leaks. Allow to cool and top of radiator. Fill the reservoir between "Full" and "Low".
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 06-12-2009, 08:12 AM   #7 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
i've changed both i4 and v6, 4cyl is much easier, only held by three of 10mm nuts, located under the alternator, if you trace the upper radiator hose on passenger side to the engine, u will find it.
the v6 is a bitch, took me a good 45 minutes to an hour. located on the side of the front bank, (driver side), proper tool will make it easier, i used 10mm socket (1/4" drive), 1/4" swival, and different 1/4" extension, 2", 4", 6", 8" to get to the 3 bolts on the thermostat housing, and have to remove air box hose that connects to the throttle body to give more working room, and remove what ever is on the way. the coolant heater hoses and engine wire/harness also on the way,
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
