P0401 egr code - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2009, 01:44 AM   #1 (permalink)
View Redsw21guy's Photo Gallery
P0401 egr code
Today i have a dtc came on and it turn out to be the p0401 egr flow code. So far i check the following. but code still return. 1998 v6 camry
1) apply vaccum to egr valve with engine running and it does stall the engine when vac. is apply.
2) ohm the egr position sensor and it turn out to be in spec. 2.5kohm.
3) ohm the egr vsv and it was 32 ohm. than check air flow from port e to port g. air was flowing. next i apply b+ and check air flow from e to f. air was flowing from e to f also. so it good
4) remove the egr valve and clean it by spraying carb cleaner into both hole of the valve. my question is that should the fluid be pouring out from one end to the other? because when i fill it on one end it take a while for the fluid to drip out of the other end. is this normal? or should it flow out rigth away?
5) test drive it for about 30min. light still came back on with the same code. p0401.
any idea on what else could cause the mil? does it sound like my egr valve is bad?
thanks.
Redsw21guy is offline   Reply With Quote
Old 06-11-2009, 04:12 PM   #2 (permalink)
slpr1mz FTW :-)
slpr1mz's Avatar
View slpr1mz's Photo Gallery
i had this code... except excessive... i tried a different scan tool and it said it was the sensor... pay 35 for the position sensor instead of 30 for the valve... but yea. there will be a leak. i dont exactly remember how much but there was flow. take the cast iron piece off and spray cleaner into that, and into the hole that is on top of the intake manifold. spray cleaner into the throttle body too. just to help clean it out...
loves it when i make ppl regret not downshifting ;-)
TRUST YOUR DRIVER RESPECT YOUR MONKEY
http://www.cardomain.com/id/slpr1mz
slpr1mz is offline   Reply With Quote
Old 06-11-2009, 11:30 PM   #3 (permalink)
anyone else any idea on why the code is still there? Did it sound like i check all the sensor correctly? maybe i miss something.
thanks
Old 06-12-2009, 02:21 AM   #4 (permalink)
View DaiFai's Photo Gallery
Did you check the EGR VSV?
DaiFai is offline   Reply With Quote
Old 06-12-2009, 06:04 PM   #5 (permalink)
Yes
Old 06-13-2009, 03:26 AM   #6 (permalink)
If you're sure the EGR VSV is working fine and the vaccum hose to the valve is not leaking, it could be the EGR valve binding when engine is hot. Since P0401 is for insufficient flow, and you said the EGR pipe is not plugged. I would consider the valve is no good.
And can you upload a picture of the EGR positioning sensor, there's a updated sensor for 1MZ-FE.
Old 06-13-2009, 11:04 PM   #7 (permalink)
View knkreb's Photo Gallery
I had a similiar problem just about 2 years ago... IF the VSV is stuck, you will get the EGR valve to flow, but it will flow under all conditions, and not just the prescribed speed and RPM range that it is supposed to open up. If the computer does not see the MAP pressure change when it commands the EGR open, it thinks that it is not working... only problem is: it's working all the time, and the computer doesn't know it. So, it flags it as insufficent flow.
Hope that helps!
knkreb is offline   Reply With Quote
Old 06-14-2009, 04:59 AM   #8 (permalink)
The computer knows where the valve is, because there's a positioning sensor on top. And if the VSV stuck ON all the time, it will cause rough idle, the code will be excessive flow instead of insufficient.
Old 06-14-2009, 06:50 PM   #9 (permalink)
thanks guys for the input. I am going to try putting a new egr valve and see if it will fix it.
Old 06-15-2009, 06:39 PM   #10 (permalink)
I think that there are several verisons of these systems. Mine had no positioning sensor on top. It was a neat fail-safe approach of EGR valve was regulated by the regulating valve, so it never went excessive. It would "function" normally as an EGR, it just did it all the time, instead of prescribed conditions of over 35 MPH, and specified RPM.
This was on a 97 Camry 2.2L IL4.
1997 Camry 2.2 4 cyl 135,000 miles. Owned since new at 67 miles. Great car, hardly any issues in 12 years!
Old 06-16-2009, 02:31 PM   #11 (permalink)
so it turn out the egr valve was bad, p0401 is gone now. All monitor have ran to completion including egr.
