Help please 98 Camry missing! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2009, 04:00 AM   #1 (permalink)
View Chris_Camry's Photo Gallery
Hi
Recently bought a 2.2 litre 98 Camry
long story short, ever since i bought the car it has had a slight misfire. I just thought it would need a good service but I have now done this and am still having issues. I have changed the oil, the coolant and the whole ignition system I believe including plugs, leads and the coil/ignitor packs.
This has definitely improved things but there is still a slight miss Have I missed something or is there anything else I should be checking on these cars??
Thanks Chris
Chris_Camry is offline   Reply With Quote
Old 06-11-2009, 01:18 PM   #2 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Check the timing.
Chris Crash is online now   Reply With Quote
Old 06-11-2009, 08:53 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Has it been tuned up? Like timing belt, valve clearance, injector cleaning (Chevron Techron fuel system cleaner).
With an old car, you never know how good these parts are. Maybe run a compression test or leak down test on this unknown engine?
Originally Posted by Chris_Camry View Post
Hi
Thanks Chris
Old 06-12-2009, 01:03 AM   #4 (permalink)
Gameroom cash: $303255
^ I agree with JohnGD. If you are really getting a missfire and you have already changed all the ignition system components, it could be caused by a clogged fuel injector. The Chevron with Techron is a good thought. I would also do a thorough cleaning of the throttle body. Here's a good thread on how to do it:
How to: Cleaning Throttle Body -4 Cylinder Engines- With Pictures
Mike
Old 06-12-2009, 01:18 AM   #5 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
Probably a dumb question but are you running the A/C? If so, try driving with it off and see if you still have the 'slight' misfire. I would swear my '01 and '04 are misfiring but it's just the compressor loading the engine when it kicks on. Might check it with a code reader too. It might show something if it is misfiring.
Dave's is online now   Reply With Quote
Old 06-12-2009, 03:21 AM   #6 (permalink)
cheers fellas, haven't actually had the timing checked so will get on that.
One thing I thought of was the sensors though? Would I need to test all of these seperatly or will sticking it on the diagnostics tell me if there's an issue?
Thanks for all the replies!!
