$430 is a joke. These things can be cleaned with a $4 can of throttle body cleaner and a small toothbrush. If you need a new gasket, it's like $2 at Autozone.
IAC failures are common on Toyotas because they used a bi-metal thermostat spring instead of information from the ECU on RPM, coolant temp, air temp, and a strong stepper motor to operate the rotary valve. Well, could have been better designed I guess.
Google on "camry IAC cleaning" for everything you need to know. See also:
http://www.autosafety.org/valve-prob...lenty-suspects
If you really need a new one that will plug up next year, it's $166 (Non-Calif) - $185 (Calif) + shipping:
http://info.rockauto.com/SMP/SMPDetail3.html?AC194.html
Originally Posted by mnsweeps
In mornings the idle very low and engines dies if I dont step on the gas....I did old change with dealer today and he recommended replacing the IAC valve to fix it. Mine is a 99 camry with about 107000 miles on it...He said cost is around $430 ....
any recommendations ?
