5S-FE engine sound - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2009, 02:53 PM   #1 (permalink)
View Camry1111's Photo Gallery
5S-FE engine sound
Hi
I've had a 94 camry 2.2 for about a month and wonder how the engine should sound on these cars.
its got 202km(120Miles) on it
It seems to me that there are various sounds that are a bit strange but im not sure if its just the engine running like this or if something could be in need of attention.
Cold start:
  • Slight whining noise (dissapears after 2-3 minutes)
    • I have just replaced water pump and timing belt(sound was like this before and after change)
Acceleration:
  • between 2-3k rpm it sounds a bit rough
    • 1-2k rpm = Hummm
    • 2-3k rpm = BRRRR (growl)
    • 3k- rpm = Hummm(slightly growly but not as much as between 2-3k)
  • The BRRRRing between 2-3k seems louder when engine is cold
  • Could this be some ignition knocking(havent tried higher octane fuel yet)?
I have just replaced air filter and spark plugs allso, engine sound havent changed
Otherwise the engine seems in good condition. good fuel economy(7L/100km, 35mpg) and idles nicely.
Camry1111 is offline   Reply With Quote
Old 06-11-2009, 03:41 PM   #2 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
It's hard to describe how an engine sounds using words, but your description is about what my engine sounds like as well.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 06-11-2009, 03:58 PM   #3 (permalink)
TN Avid Fan and lurker:)
dipstick97's Avatar
View dipstick97's Photo Gallery
Camry engine really is not a silent mover... has power but you really have to tolerate the engine noise. Newer cars has engine shroud cover to lessen the noise, mine gen 4 camry sounds same too.
01 MDX / 97 Camry Gen 4.0 - Still A1 ! to All
dipstick97 is offline   Reply With Quote
Old 06-11-2009, 08:42 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Whining noise: is it coming from the alternator or the transmission area?
If bearing (AC clutch, alternator, timing pulleys) would be more with grinding sounds as well.
It would help to locate the general area of the noise. Be careful of moving engine parts.
Originally Posted by Camry1111 View Post
Cold start:
Acceleration:
    • 1-2k rpm = Hummm
Old 06-11-2009, 08:53 PM   #5 (permalink)
View idrum2loud's Photo Gallery
Acceleration:
    • 1-2k rpm = Hmmm ( Sound of engine wondering what your doing )
    • 2-3k rpm = BRRRR ( Sound of engine finding out what your doing )
    • 3k- rpm = Hmmm! ( Sound of engine before flux compacitor kicks in )
idrum2loud is offline   Reply With Quote
Old 06-25-2009, 04:46 PM   #6 (permalink)
Seems to me like the whining noise comes from somehere around the top of the engine. cams or maybe inlet manilfold? definitely not the alternator.
Could the camgears be running dry until oil is circulating propperly?
No grinding noise as far as i can tell. Maybe some slight ticking from the walves. i'll check if the ticking is there when engine is at normal operating temperature tomorrow. I havent got AC so rule that one out.
Or is it just be the normal sound of this engine. Its built for durability, not to sound like a ultra smooth rolls royce V12 engine built by an army of swiss watchmakers. If i use my imagination it sounds a little bit like a tiny bus or truck engine. which i would guess is made entirely for durability.
Old 06-26-2009, 08:36 PM   #7 (permalink)
I work on euros.
View 96CamrySport's Photo Gallery
trust me, you're glad it's not a v-12 rolls engine. An oil change would cost more than your car.
Cam gears don't really run dry...unless you're leaving it to sit for a year. Then they'd be lubricated within about 10 seconds anyway. At 202k, your engine is getting a bit loose, don't worry about it. And engines make noise. Maybe check the timing belt tension and drive belt tension, but personally, I'd recommend turning the radio up a little.
Oh, and the 4 cyl engines seem to like to tear the torque strut a the top of the front of the engine. Then the engine moves too much, excercises the flex joint and breaks it. Then you have an exhaust leak. whee.
1996 Camry Sport (that's a DX Coupe with decals) with 186k
european cars are just like japanese cars, just heavier and more expensive.
7 ASE's.
96CamrySport is offline   Reply With Quote
Old 06-26-2009, 08:51 PM   #8 (permalink)
View gonesurfing's Photo Gallery
I also have the top end whine on a 94 5S-FE. It appears to come from under the valve cover, but have never identified a cause. Has gotten a little worse over the last year. I always attributed to the lack of maintenance the vehicle had before I inherited it.
I do remember some noises after changing the timing belt and water pump, that went away after the first few minutes.
Another noise I have never been able to put my finger on, is a "ringing" or fluttering noise that the engine makes around 5,000 rpm at WOT. It doesn't sound bad, just noticeable above other engine noise.
gonesurfing is offline   Reply With Quote
Old 06-26-2009, 08:54 PM   #9 (permalink)
Banned
View trinity03's Photo Gallery
better check your alternator....
trinity03 is offline   Reply With Quote
Old 06-26-2009, 09:04 PM   #10 (permalink)
I work on euros.
that's about where the intake/throttle body maxes out. if you put a vacuum gauge on and do a full-throttle pull to redline you'll find that that's about where it starts making vacuum again. Doesn't really go past 2-3" of vacuum before you hit rev limit.
7 ASE's.
Old 06-27-2009, 07:32 PM   #11 (permalink)
Bdub215's Avatar
Gameroom cash: $315565
View Bdub215's Photo Gallery
http://www.youtube.com/watch?v=xZr37mNaEVc it may help it may not. but you'll notice that sound at 5k
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
