1999 Toyota Camry LE
On monday morning, my third brake light went out, the usual "check brake lights" light goes on. So i went to autozone and picked up a set of new bulbs, put it in and it was working fine. But the problem is the "check brake lights" light came on again, im like WTF?!
So i ask my mom to tell me which lights were out and she said none. Ok, i wanted to check myself and she was right all working fine. Then i checked the parking lights, all working fine. So im confused. As a just in case i bought new taillight bulbs and replaced the ones that were there, still same problem. All brake lights are working properly and so are the parking lights. I thought the cpu might be dumb so i disconnected the battery for a while and thought that cleared up the issue...nope "check brake lights: light still comes on...What should i do?
1993 Toyota Camry LE Wagon
So my cousin recieved this 16 year old wagon, its fine and start up real strong, but he lives in New Hamsphire and failed inspection. We fixed most of the problems but there is one really bad one....heres the picture.
Im guessing this is the rear subframe, what can be done in order to fix this? I was thinking of getting one ( if we're lucky enough ) from a junkyard...
Also, the inspector said that his brake lines had to go to this:
I have no idea what this piece is, and it has a block thing on top of it, my cousin was told by the inspector that it was some load thing for the wagon and cannot pass inspection without that properly working...how can i fix this?
