Common problem. Try taking a dremel tool to the inside of the bay where the radio goes. There's really nothing you can hit in there that will mess anything up. Just make sure you can see what your doing (work light) and use common sense, of course.
edit: Kevin, he's taking about rear clearance, as in depth.
'07 Honda Ruckus Big Bore TOTALED: '03 Ford Expedition Eddie Bauer 4x4 5.4L, '96 Camry LE 5S May '10: '11 Sienna V6 XLE FWD 8-pass. July '10: '06 Matrix XR Auto FWD Oct. '09: '05 RAV-4 L 4WD
Oh, ok. If it's rear clearence you need, try doing your wiring as neat as possible and keep it bunched together. Then when putting the radio in, direct the harness into the lower right hand corner, there is a space there that the extra wiring will fit into.
wasnt that the tip i gave you?
No? You gave it to another guy in another thread that I was a part of, but it was not directed at me.
same thing, more or less. shows youre paying attention.
I have a problem in my 1996 camry le. I am trying to install an aftermarket radio which i got on eBay. I got all the diagrams amd connected everything with butt-splice crimps instead of a wire harness. I tried to turn on the radio but had no power. I also noticed the clock and the dome light power were out. However, the cigarette lighter is still working fine. I even undid the wires and wired it again and the same problem occurred. Any suggestions? I thought it might be the fuse, but the cigarette lighter is on the same fuse? Please help if you know anything on the subject.
