hot weather problem 2001 Camry 5SFE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2009, 07:26 PM   #1 (permalink)
cmryhldr's Avatar
View cmryhldr's Photo Gallery
4th Generation hot weather problem 2001 Camry 5SFE
I have a problem that only shows up in hot weather. When the outside temp gets up to about 90 degrees on a sunny day and I do not start my car until up in the afternoon (about 3:00) then it runs rough for a few seconds and then smooths out. It starts fine after that and also if I start in the mornings. Seems like it has to sit in the hot sun before this happens. If I switch it on and wait a few seconds that seems to help most of the time. I did a search and couldn't find anything. Any suggestions or fixes? Thanks
cmryhldr is offline   Reply With Quote
Old 06-15-2009, 08:43 PM   #2 (permalink)
View 1996camry's Photo Gallery
sound like your cooling temp. sensor goes bad.
1996camry is offline   Reply With Quote
Old 06-19-2009, 03:05 PM   #3 (permalink)
cmryhldr's Avatar
4th Generation
Where is my cooling temp. sensor? All I can find is a coolant temp sending unit.
Is this different than my coolant temp sending unit?
