Problem With Cams, Please Help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-17-2009, 05:39 AM   #1 (permalink)
decrypted's Avatar
View decrypted's Photo Gallery
USA Problem With Cams, Please Help!
i replaced the head gasket on my 93 camry (3vzfe). and im a the cams right now the book says to line up the dobble dots on each cam but then the valve timeing seems off. if i alin just the single dots like when i took it off it seems to line up. not sure how to line up the cams need some help please have looked all around?
decrypted is offline   Reply With Quote
Old 06-17-2009, 02:06 PM   #2 (permalink)
View davemac2's Photo Gallery
I think you will be fine if either the single or double dots are lined up since once you rotate the cams when they are in, the 2 double dots and single dot pairs will be aligned as they pass by each other, no?
You can see a few photos of my 3vz-fe hg job on photobucket. Here is a pic of my cams aligned to the single dots which is the resting position they were in at TDC for cyl #1:
The real question though is are the back and front cam pairs aligned using the same single or double dot pairs for a given cam position once the belt is back on? I can't remember that. You should be able to figure that out though given the firing order.
dave mc
davemac2 is offline   Reply With Quote
Old 06-17-2009, 02:30 PM   #3 (permalink)
decrypted's Avatar
sweet, thank you
Old 06-17-2009, 04:42 PM   #4 (permalink)
decrypted's Avatar
im have troble with the exsaust cam lining up. any idea why?
Old 06-17-2009, 06:06 PM   #5 (permalink)
did you lock the cam gear tensioner in place with the bolt in the gear before you removed it and kept it lock until the cam was reinstalled and meshed with its corresponding cam? Otherwise you should not have a problem. Are you mixing up the intake and exhaust cams? Intake cams are always on the inside and exhaust cams closest to engine sides.
dave mc
Old 06-18-2009, 03:44 AM   #6 (permalink)
decrypted's Avatar
3rd Generation
i figured it out. the bolt got loose a little and made it so that the tenchiner gear was slightly off and made the cam gears not want to mesh together. all the cams and pulley are on. thank you for your help
Old 06-20-2009, 08:12 PM   #7 (permalink)
View efont12's Photo Gallery
USA i have the a problem with my 2001 camry!!
i just replaced the headgasket on my 2001 toyota camry 2.2 , because oil was leaking and my timing belt broke on me . so this was my first time taking the car apart , when i got the head back with both cams , i dont know how to align the cams nor the crankshaft , can somebody help me with this problem ?
efont12 is offline   Reply With Quote
