99 Camry: AC gets wet and stops working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-17-2009, 01:34 PM   #1 (permalink)
View Cannonbolt's Photo Gallery
4th Generation 99 Camry: AC gets wet and stops working
When the front end of the car gets real wet (as in I hit a decent sized standing puddle of water) the AC light begins to blink and the AC won't blow cold. This is bad when I can't defog the windshield and then I can't see to drive the car. Is there a short somewhere? Any ideas? Thanks in advance.
Cannonbolt is offline   Reply With Quote
Old 06-17-2009, 01:50 PM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Check A/C Clutch connector and wire, then check accessory belt for tension or wear, make sure Accessory belt is not slipping when wet.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 06-17-2009, 01:52 PM   #3 (permalink)
View davemac2's Photo Gallery
I second the above. It's likely your belt tensioner and the A/C pulley is slipping.
dave mc
davemac2 is offline   Reply With Quote
Old 06-17-2009, 08:24 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
If it's belt tension then it is the disadvantage of not having an automatic belt tensioner (jack screw is cheaper). Belt stretches over time and can become loose.
I recommend getting an inexpensive tension gauge like the following from your local NAPA store. I think you need 110 lb???
http://www.gates.com/brochure.cfm?br...cation_id=2742
