Originally Posted by 96paseo
Don't be in rush to replace the O2 sensors just yet. Your "Sytem too lean" code is the first issue to deal with. Check your rubber intake pipe that goes from the air box to the throttle body. The pipe can crack and let in extra air. Also check that all your vacuum lines are properly attached.
Thanks for all the help, guys. I really hope it's not the O2 sensor, since it was just replaced in 2004. I think it was replaced with an after market sensor, so I guess that could be it, though. I'll check the intake pipe and the vacuum lines and report back. Thanks again. I'm due for my NY inspection in July so I just want to get it taken care of to pass the inspection (automatic fail in NY if CEL is on).
