NEED HELP with rear brake job!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2009, 09:46 AM   #1 (permalink)
Official TN user
Tuner571's Avatar
View Tuner571's Photo Gallery
Well I did the fronts yesterday and it went very well. However, I am stuck on the rear pads today. I was able to hinge the caliper up, take out the old pads, insert the new pads, and push the caliper piston back in. However, now I am stuck because even though the caliper fits around the new pads I need more clearance to put back the bottom bolt. I would appreciate any help.
Thanks
95 Toyota Camry V6
http://www.cardomain.com/ride/2489322
Tuner571 is offline   Reply With Quote
Old 06-18-2009, 11:44 AM   #2 (permalink)
View davemac2's Photo Gallery
make sure the new pad size matches the old ones. I've had wrong pads given to me in the past.
dave mc
davemac2 is offline   Reply With Quote
Old 06-18-2009, 03:08 PM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
did you compress the rear caliper piston all of the way before you installed the new pads?
Old 06-18-2009, 04:04 PM   #4 (permalink)
Gameroom cash: $283230
View LE05's Photo Gallery
are you pushing in the bottom slide pin (where the caliper bolts to) while putting the caliper back into place? sometimes the slide pin will push itself out a little more when you remove the caliper... preventing you from putting the caliper back into place.
if thats not the case, you can always loosen the top bolt to give yourself some more clearance.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is online now   Reply With Quote
Old 06-19-2009, 09:02 AM   #5 (permalink)
Official TN user
Tuner571's Avatar
Thanks LE05, that was the problem. It took some force to push it back, but once it did everything went perfect.
Thanks again guys.
95 Toyota Camry V6
Old 06-19-2009, 11:57 AM   #6 (permalink)
Gameroom cash: $303255
"It took some force to push it back"
That might be an indication that slide pin needs to be relubed.
Mike
