97 camry frnt strut: stabilizer bar stuk - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2009, 11:00 AM   #1 (permalink)
View dave52's Photo Gallery
Trying to remove/replace front left strut. Everything is losened and the only thing holding me up is the attached stabilizer bar nut. The picture seems to indicate the stabilizer bar screw/pin goes through the strut mount and is just held on with nut. I've loosened the nut many turns but not getting anywhere. the bolt just turns with the nut: nothing on back of bolt as it is part of the stab bar. I'm cautiously looking at a somewhat exposed brake line behind this stab bar and am a little leary about continuing.
Thanks/Dave
dave52 is online now   Reply With Quote
Old 06-18-2009, 02:36 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
does the end of a stud have a hex shaped hole in it? it may require an allen wrench to hold it while you turn the nut. toyota likes to do that.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 06-18-2009, 06:02 PM   #3 (permalink)
I figured the stabilizer bar link was defective so I called parts store and was told they're all like that: even the new one he had in stock that was less than $20. The stud is attached to some kind of ball in the the SBL that can turn. He suggested putting it in a vice grip or grabbing on to the stud somehow: I don't understand. He just said they're all like that? I just don't see an area of this screw where I can grab onto it with anything.
Thanks, Dave
Old 06-18-2009, 06:16 PM   #4 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
I changed my struts last week and came across this as well.
The end of the stud should indeed have a hex-shaped hole. It might be covered by road grime and you may not be able to see it. Spray some WD40 or PB Blaster to clean it, then use a hex key of the correct size to hold the stud while you turn the nut with a combination or dogbone wrench.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 06-18-2009, 09:43 PM   #5 (permalink)
WOW!!!! BIG help: Thanks big time for the tip Tom 2000 !!!!!!!!!!!!!!
