How to remove distributor on 94 camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2009, 03:16 PM   #1 (permalink)
View borisp@gmail.com's Photo Gallery
Hello,
I have a 1994 cali 4 cyl camry. I wanted to take out the distributor to replace the distributor o-ring, but I can't figure out how to remove the distributor. I completely took out the bolt that prevents the distributor from rotating, and could rotate the distributor very easily, but it wouldn't come out. I can't see anything else holding it, but as hard as I pull on it it doesn't come out of the head. Is there something holding it under the valve cover? Please help, I am compeltely puzzled. Also, mine is a round distributor, not the recrangular one found on many that I've seen in pictures. I think it may be different on a cali vs. non-cali car, but not sure.
Thanks.
borisp@gmail.com is offline   Reply With Quote
Old 06-18-2009, 04:04 PM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
There's a second bolt hidden under the dist. housing on the other side opposite the bolt you took out.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 06-18-2009, 04:12 PM   #3 (permalink)
Thanks for your replay. I can't see another bolt though. Also, if there is another one, what does it attach to? When I loosen the first bolt, the distributor rotates freely. There is a connector on the other side of the distributor, so perhaps the bolt is somewhere underneath it, otherwise I can't see it.
Old 06-18-2009, 04:38 PM   #4 (permalink)
View angel_rolla's Photo Gallery
take the valve cover off
angel_rolla is offline   Reply With Quote
Old 06-18-2009, 06:15 PM   #5 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
The other bolt is hard to see with the intake pipe in the way. You can remove the intake pipe along with the upper half of the air filter box to get some working room to remove the bolt. This will also give you some space to get the distributor out.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 06-18-2009, 10:33 PM   #6 (permalink)
View gtturbo93's Photo Gallery
2 bolts, one at 9 o'clock and one at 6 o'clock.
gtturbo93 is offline   Reply With Quote
Old 07-13-2010, 01:41 PM   #7 (permalink)
View marshalljarreau's Photo Gallery
I have the same problem!!
I have been having the same problem. What did you do to fix it?
I read the manual and did everything it said: Disconnected the negative battery cable, removed the air hose, disconnected the distributor connectors and the high-tension cords from the spark plugs.
I removed TWO bolts form the housing, one from the left side and one from underneath. But I could not pull it out!
I took the cap and rotor off as I am replacing the hole thing. The distributor housing rotates slightly from left to right, but the shaft in the middle stays put and goes nowhere.
Did I miss something small yet enormously important??
Please help.
marshalljarreau is offline   Reply With Quote
Old 01-01-2012, 09:27 AM   #8 (permalink)
View geezee's Photo Gallery
I realize this is an old thread. C'mon you all post COMPLETE replies, two bolts are NOT all that holds the Camry dizzy onto the engine. The poster is asking how to remove, not rotate, the dizzy. Big diff..... Help a DIY'er out a bit, huh ? I have done this 3X now, and I do think it requires removal of the Valve Cover (A HORRIBLE design, thanks Toyota wingnuts!) to 'unlock' the Dizzy from the engine. Yes, it can rotate with the two bolts removed (or loosened), it will not come out, however...
geezee is offline   Reply With Quote
Old 01-01-2012, 11:14 AM   #9 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
No you don't have to remove the valve cover.
I completed this about 3 months ago without removing it.
RichieRichJP is offline   Reply With Quote
Old 01-01-2012, 07:51 PM   #10 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
gezee, I don't lknow what brought on your tirade on a 2009 thread, but you don't need to remove the valve cover. Happy New Year!
It worked fine until I fixed it!
csaxon is online now   Reply With Quote
