Question about HIDs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2009, 08:12 PM   #1 (permalink)
DJT853's Avatar
View DJT853's Photo Gallery
4th Generation Question about HIDs
I couldnt find this question posted anywhere, so I'm askin' it.
Im thinking of installing a simple plug and play HID kit on my 2000 camry 4 cylinder. Will I need to change a fuse or anything like that, and if so, could someone point me in the direction of something that would tell me what to do specifically? Thanks
Dougy
My ride: The 2000 Camry LE I4 in Silver
DJT853 is offline   Reply With Quote
Old 06-18-2009, 08:14 PM   #2 (permalink)
PortugalFocus's Avatar
Gameroom cash: $124395
View PortugalFocus's Photo Gallery
No, plug and play systems are designed to do just that.
You should not need to change any fuses or wiring for that mature. The reason being that HIDs draw about half of the current that regular halogen lamps do.
PortugalFocus is offline   Reply With Quote
Old 06-18-2009, 11:00 PM   #3 (permalink)
DJT853's Avatar
Okay thanks. Thats what I though, I just wanted to make sure
Dougy
Old 06-20-2009, 05:39 PM   #4 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $294873
View Buurin's Photo Gallery
The reason there are worries of fuse and wiring and such is that all HID systems will draw a lot of current - up to 15A each side - during the first few seconds of turning on. After that the current slowly decreases to about 2/3 of a regular bulb. That's the measurement from mine.
Also please read this:
Mandatory Viewing Before Considering HID Conversions.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 06-20-2009, 06:04 PM   #5 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568401
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
There are no simple plug and play HID systems. If you do take the plunge for the HID kit, you will need to purchase an HID relay kit to go along with it. Also, you will most probably have to aim the headlight DOWN afterwards as to not blind other drivers.The thing about HID's is the start up current. It's pretty darn high and that's where the biggest risk of frying your stock wiring is, hence the placement of a relay kit for HID's.
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 06-20-2009, 07:59 PM   #6 (permalink)
View DAT RICE's Photo Gallery
how dangerous is this to a third gen camry? i just want the white HID plug and play lights, the 9006 or w/e ones.
DAT RICE is offline   Reply With Quote
Old 06-20-2009, 08:06 PM   #7 (permalink)
TN's Mad Chemist
^^^ I'm not sure I understand the question but I will answer to the best of my understanding. If you are refering to the voltage surge, which Gen the car is really doesn't matter, it's simple electronics. If you are buying a 100$ HID kit, a 5$ relay won't hurt. All electronics set aside, the next big worry is glare. I saw a poorly installed HID kit the other day and let me tell you, her must have been doing some real squirrel spotting You would think he had his highs on or something. To solve the glare, simply lower the headlight beam. If your gen 3 has a similar headlight design as my 3.5, which I'm guessing it does, it's that little phillips head screw on the outside of the headlight.
1997 Acura RL-Gone
Old 06-20-2009, 08:54 PM   #8 (permalink)
i meant what's the chances of frying my stock wiring
Old 06-20-2009, 10:22 PM   #9 (permalink)
TN's Mad Chemist
I'm not really sure what are the odds of frying it, but all you need is once!! Save yourself the trouble, spend the 5$ and the extra 30 seconds installing it. It just might save you a lot of money and a major headache down the road...
1997 Acura RL-Gone
Old 06-21-2009, 02:02 PM   #10 (permalink)
good idea, what exactly ami looking for?
Old 06-21-2009, 02:13 PM   #11 (permalink)
TN's Mad Chemist
You are looking for something like this:
http://cgi.ebay.com/ebaymotors/9006-...lenotsupported
It's a 9006 HID relay kit, the ebay one's shipping is 10$ and he's selling the kit for 1$ Do your research, but you are looking for something like that. It takes it's power from the battery like I said before, uses the headlight harness as just an on/off switch and not the power source, and will ground at the light. It only hooks to the positive end of the battery. Here is the install sequence: Headlight harness to HID relay to ballast to HID light. Essentially, you install it before the HID kit
1997 Acura RL-Gone
