Brake problem, easy diagnosis? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2009, 05:05 PM   #1 (permalink)
Proud Camry owner.
Loganwiththe'93's Avatar
View Loganwiththe'93's Photo Gallery
3rd Generation Brake problem, easy diagnosis?
Hey guys.
Since I bought my car, the ABS light has been on. The car also makes a grinding kinda sound when you brake, and there is pulsation/feedback in the pedal. The best way to explain it is like a one second interval in braking. It feels kinda similar to a bent rim on a bike tire when you're braking. I suspect a warped rotor, but I can't really tell- the last time the tires in the front were off, was when I was getting new ones. I couldn't really see any warping, but again, my eye isn't trained to see that kinda thing. My dad tells me it's the ABS. When I took the car to the mechanic, he determined the ABS speed sensor, I think, in the passengers-side front tire was the faulty sensor, causing the ABS light to come on, but I don't recall speaking with him about the grinding.
The vibration/grinding is okay for a little while, such as after a night of sitting. I can drive it off, and the brakes feel fine for a bit, but then the more I drive/hotter it gets, the grinding sound and pulsation becomes more substantial. Any ideas/tips/quick fixes? It's a 1993 LE 4 Cyl.
1993 Toyota Camry LE 4 Cylinder
Running 100%
Loganwiththe'93 is offline   Reply With Quote
Old 06-19-2009, 11:37 PM   #2 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
View JCamry94's Photo Gallery
3rd Generation
That's either warped rotors or your pads are worn out, fix immediately
You can get rotors resurfaced, or just buy new ones, and obviously get new pads!
ACCIDENT...
Help me bring 'er back to life!!!
BUY MY STUFF: http://www.toyotanation.com/forum/66...e-all-obo.html
Thanks
JCamry94 is offline   Reply With Quote
Old 06-20-2009, 09:46 AM   #3 (permalink)
Proud Camry owner.
Hehe. I don't think it's the pads...
When I had my rear brakes replaced, he said my front ones were practically new. Would like uneven wear on the pads cause this?
And I was thinking about getting my rotors resurfaced. I just need to save up the money to do it. I also wanted to check here, and see if it was the faulty ABS that was causing it, before I did anything.
Running 100%
