Originally Posted by JohnGD
There was a DIY somehwere in google groups I read. I think you also have to pull out the plastic trim panels from the rear window C pillar.
No, those panels don't have to be removed.
1) remove the back seat bottom by pulling up at the front edge
2) drop the seat backs
3) remove the side bolsters by removing the 10mm bolt at the bottom, then slide them up and out
4) remove the "gasket" around the pass through opening
5) remove the plastic trim panels on either side of the pass through
6) remove the 2 screws on the front of deck trim panel
7) remove the 3rd brake light housing
8) remove the 3rd brake light reflector assembly (10mm bolt)
9) pull deck trim panel forward
10) remove rear speakers (10mm bolts)
That should be it. Well, that's what I remember from when I upgraded my rear speakers a year ago.
