Yeah, go with NGK Iridium or for a couple of bucks more, the Laser Iridium with platinum ground pad. The latter plug are spec'ed 120K miles on Toyotas.
IMO Denso are cheap plugs. They tend to more stingy on platinum and such. The old NGK plats I pulled looked so much better than Densos after 60K miles. Now I only use NGK Iridiums unless they aren't avaiable.
www.ngksparkplugs.com
2000 TOYOTA CAMRY 3.0 V6 1MZ-FE FI DOHC
Spark Plug Part No. Stock No. Plug Gap Photo Standard BKR6ES-11 5553 .044
V-Power BKR6EYA 2249 .044
G-Power BKR6EGP 7092 .044
Laser Platinum BKR6EKPB-11 * # 3452 .044
Iridium IX BKR6EIX-11 3764 .044
Originally Posted by ero
Hi, I need to know what the appropriate gap is for plugs for this car.
Also, if I needed to replace the plugs, which ones would be best to go with?
Lastly, what is the proper torque to tighten to?
