testing water temp gauge.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-21-2009, 08:37 PM   #1 (permalink)
View sc2dave's Photo Gallery
My gauge never goes past the half mark,no matter what. how can i make it go all the way up,as in disconnecting the sensor wire and doing something so as to make it think it's overheating? 95 5sfe auto
sc2dave is offline   Reply With Quote
Old 06-21-2009, 09:14 PM   #2 (permalink)
View flyeri's Photo Gallery
Mine never gets to half scale. What are you trying to accomplish by having it indicating hot?
flyeri is offline   Reply With Quote
Old 06-21-2009, 09:54 PM   #3 (permalink)
i want to see if the gauge can physically go all the way up, to determine if it indeed does work properly
Old 06-21-2009, 10:03 PM   #4 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
You can remove the connector and ground it to the engine block. Insert a wire into the connector and ground it, then check the gauge. It should go all the way up. Do this quickly so you don't hurt the gauge. If the gauge works normally, replace your sending unit. I suppose you have changed your t-stat and your heat works?
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 06-22-2009, 01:26 AM   #5 (permalink)
It has plenty of heat and the gauge seems to go to the half mark pretty quick. Nope, haven't changed t-stat
Old 06-22-2009, 01:36 AM   #6 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
same here, i have a coolant leak somewhere without the reservoir tank and my needle never goes past the half way mark i dont know why but im not complaining. I check my radiator frequently and there is always coolant there and the oil isn't milky and neither is the trans oil, but testing the connector should be a good way to check if its working though
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 06-22-2009, 01:43 AM   #7 (permalink)
I work on euros.
View 96CamrySport's Photo Gallery
ummm....gauge doesn't move between 190-230 degrees F. That's designed in. 190 is the thermostat's set point, 230 is when the fan turns on. Only time I've ever seen it go any higher was after an auto-x, 2 minutes of balls to the wall driving and I only broke 60 once (small track). Ground it to verify the gauge range, then leave it alone - it's working normally.
1996 Camry Sport (that's a DX Coupe with decals) with 186k
european cars are just like japanese cars, just heavier and more expensive.
7 ASE's.
96CamrySport is offline   Reply With Quote
Old 06-22-2009, 09:16 PM   #8 (permalink)
What 96 said. Just go with what is normal on your car and pay attention to any abnormal changes. Kinda like running the tank to empty to see if the gas guage will go all the way to "E."
Old 06-22-2009, 09:56 PM   #9 (permalink)
View toysarefun's Photo Gallery
Pull the sensor (to easy), and immerse it in boiling water. Then you'll know where 212 is! Something like a soldering iron or blow torch would push the gauge up further. While you have the sensor off, test it with an ohmmeter to see if it's within OEM spec if you want. Oh, btw, it sounds like your cooling system is working perfectly and the gauge is right on.
toysarefun is offline   Reply With Quote
