General question about temp gauge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2009, 10:18 AM   #1 (permalink)
Woo Hoo!!
sbushnak's Avatar
Gameroom cash: $173010
View sbushnak's Photo Gallery
Good day all,
I just have a question regarding the temperature reading difference between my car and my friend's Gen4 and Gen4.5 Camrys
My temp gauge is almost at the half mark, a hair below normal and has been that way the day I bought the car.
My friends own a 1999 2.2 Manual and a 2000 2.2 Auto. When I ride with them, their temperature gauge is about over the mid point between cold and normal. It never moves when the engine reaches normal operating temperature. Heat works fine and as far as i know, their engines never overheated.
The mileage on the 3 cars are almost the same.
I am curious on why the difference between temp. reading? TIA
1997 Toyota Camry LE I4
@ 193,000 miles
sbushnak is offline   Reply With Quote
Old 06-22-2009, 11:44 AM   #2 (permalink)
View Camry LE 94's Photo Gallery
Lightbulb
Originally Posted by sbushnak View Post
Good day all,
To be honest, I'm not exactly sure... However my guess is it has to do with the actual coolant your car uses and what ratio of coolant & water are used. My friend owns a 93 Saturn... and the car does well on highway trips. However, during city driving (stop & go traffic) the temperature exceeds the midway point, going up to right before the first red "caution" mark. His coolant smells pretty bad, although I'm not exactly sure what the difference between newer and older coolant is. Hope this helps
Camry LE 94 is offline   Reply With Quote
Old 06-22-2009, 04:54 PM   #3 (permalink)
Woo Hoo!!
sbushnak's Avatar
Thanks for your reply. my 97 and my friend's have Peak 50/50 and my other friend's 99 has Toyota coolant.
@ 193,000 miles
Old 06-22-2009, 09:10 PM   #4 (permalink)
View flyeri's Photo Gallery
The guages are not calibrated as the speedo is. The temp sensor or some part of the instrument cluster may have been made by a different manufacturer canusing a slightly different reading. The fan blades could be different moving more air accross the radiator on one than the other. Mine reads slightly below half after it is warmed up. You just have to know when your guage is different than normal.
flyeri is offline   Reply With Quote
Old 06-22-2009, 10:47 PM   #5 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
The type of coolant your using won't affect the gauge reading. It boils down to two things. The resistance reading of your temperature sending unit at normal operating temperature and teh sensitivity of the gauge. When the resistance of the sending unit goes down, the gauge goes up. When your engine is cold, the resistance is high thus not allowing much voltage to flow which keeps your gauge reading cold.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
