Would a set of cheap engine mounts from E-Bay... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2009, 01:34 PM   #1 (permalink)
View dz63's Photo Gallery
...eliminate the vibration when my Camry is stopped at a stoplight? I have already changed the dogbone mount and it did nothing. I don't want to spend the $$ on OEM mounts, but wouldn't mind forking out $100 on Ebay if I knew the cheap mounts would eliminate the vibration. I am driving a 1996 Camry 5SFE 2.2L.
2002 Camry 2.4L Auto - 56K miles
2008 Corolla 1.8L Auto - 26K miles
dz63 is offline   Reply With Quote
Old 06-23-2009, 05:28 PM   #2 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
EBAY mounts are usually hard rubber which will reduce vibrations but won't minimize as much as OEM mounts which uses a softer rubber.
If your car runs well and you know it will last get OEM mounts, if you are not keepin it or going to ride it to hell get EBAY mounts or dont get any at all
92 Camry 4 cyl 5 Spd
330,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
Old 06-24-2009, 09:51 AM   #3 (permalink)
Gameroom cash: $275055
Some vibration at idle is normal for the generation 3 (1992-1996) Camry 4 cylinder engines. I am the original owner of a 94 and the car has always vibrated a bit at idle. I even drove another new car at the dealer when my car was new, as a test, and that car did the same thing. If the car otherwise runs fine, ignore it as cruisn76 suggested. Try cleaning your throttle body. That may help smooth the ilde just a bit. Here's a link on how to do it:
How to: Cleaning Throttle Body -4 Cylinder Engines- With Pictures
Mike
Mike Gerber is online now   Reply With Quote
